benneu's avatar
benneu
Dinghy towing a 2017 Ford Focus SE Hybrid
Just got this car and trying to get it ready to tow behind my motor home. The instructions from Ford are so vague, that I am afraid to drive off and do major damage to my transmission. This is what I think the correct procedure is:
The parking brake has to be off. Press the start button without stepping on to the brake.
A green blinking light will show on the start button and the accessories are on. Now step on the brake and dial the transmission knob to N. Keep holding the foot on the brake and press the L button located in the center of the transmission radio dial. The amber light at this dial will go from a constant to a very slow blinking light. On the dash it will read that the transmission is now in Neutral. Now press the start button again without the foot on the brake and the ignition will turn off. The slow blinking transmission light keeps blinking. The car should be ready to be towed.
This is the procedure I came up with, but I am not sure. I hate to find out the hard way if I did something wrong. Hopefully somebody knows exactly what to do.
Any help will be very much appreciated.
Ben
  • I just read the online third edition 2017 Ford Fusion Hybrid owner's manual as it pertains to towing behind an RV, four wheels down. The manual on page 223 seems very clear as to the steps you need to take to prepare the car to be towed. It also appears the car has a setting for "Neutral Towing". Perhaps you should Google "2017 Ford Fusion Hybrid Owner's Manual" and look at the third edition version of the manual?
  • Carryingb,
    you are correct, the car is a Ford Fusion SE Hybrid. I am glad you noticed. I cannot understand how I mixed up my new Fusion with a Focus. Thank you for the correction.
    Ben
  • Are you sure you have a Focus? They don't make them in a hybrid, and they don't have a shift dial.
    Fusion maybe?
  • The owners manual is written very vague and describes part of the procedure differently. When following their description, I am not able to shift the tranny into towing mode. The Ford Dealers did not even know that this model is towable. I think, when the light starts blinking very slow, the car is in tow mode. The problem is: I have to be 100% sure.
    Ben
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
