Gnarley wrote:
What I'm looking for is a used car perhaps a nice used 2014 -2017 that I can use as a daily driver with AWD and auto trans that gets respectable mpg and has 4 doors so I can also use it to transport my elderly parents when needed that's comfortable and somewhat luxurious with leather and quiet which has easy entry on the passenger side for both the front and rear occupants.
The easiest way and the correct way is to go looking at the cars you like that 'also' fit into your towing weight requirement. Then...…
1. open glove box of car
2. pull out car manual
3. Under recreational towing it will tell you whether the
car can be towed four down or needs a dolly.
Straight from the manufacturer is the 'correct' answer.
With my first toad, I too spun around reading all these so called complete towing articles that you will find are not complete and/or accurate.
Just read the cars manual for towing specs and the door panel for weight. IMHO I will not take info on whether any car can be towed 4-down unless I read it in the cars manual. :C
