- dodge_guyExplorer II
Bumpyroad wrote:
phil-t wrote:
moondogcooter wrote:
I'm buying a 2015 Honda Fit as a tow behind my Class A. I'm 30,000 lbs it's 2500 lbs do I need a braking system in the car? ...
Doug
"need" is a four letter word in my book, regardless of the law. WANT is a much better term for adding a braking system to your toad for dingy towing.
yep, it never surprises me that folks here will spend $100,000+ for a RV, $20,000 for a toad, $8000 for Full Body Paint to impress the neighbors, and won't spend $2000 for a safety item. they will look for some excuse, to justify not having a braking system, i.e. my MH will stop us, a towed car is not a trailer, the law doesn't mandate it, etc. etc.
bumpy
Most brake systems only operate in emergency braking situations. Normal braking and they don’t activate. So yes the coach brakes are doing all the stopping and are rated at the full GCWR. - way2rollTrailblazerDespite the law or capacities, I wouldn't set up a car to tow without a supplemental braking system and breakaway kit. We had the ready brute elite tow bars and it had a mechanical braking system included in the bar, super simple and a no brainer. You will stop quicker with less work for the MH brakes and it's just plain safer for minimal cost. Anything worth doing is worth doing right.
- Sehunter: That is a not requirements. That is just some information. Need to find the law!
- BumpyroadExplorer
Doug
bumpy - sehunterExplorer
- phil-tExplorer
Doug
"need" is a four letter word in my book, regardless of the law. WANT is a much better term for adding a braking system to your toad for dingy towing. - wildmanbakerExplorer
Lwiddis wrote:
Thank you Lawrence, Fear of loosing the Toad is the main reason we have a braking system installed on our Toads.
“Not sure what disconnected from my motor home means?“
The hitch/connector between the MH and the toad pops off, breaks, loosens, a bolt breaks.... - LwiddisExplorer II“Not sure what disconnected from my motor home means?“
The hitch/connector between the MH and the toad pops off, breaks, loosens, a bolt breaks.... - Some auxilary braking devices come with a breakaway feature that if the tow bar comes detached from the MH, a cable is pulled locking brakes on the toad.
Aux braking is a good idea, but is not always required by law. - moondogcooterExplorer
wildmanbaker wrote:
Only if it comes disconnected from your MH. In many states, a braking system is required over 1,500 pounds.
Not sure what disconnected from my motor home means? BTW Its a 6 speed manual shift.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 08, 2026
