Nope, most times folks do not need a WD Hitch system...it is that chance encounter
with Mr Murphy. Same as the seat belt...most times it is NOT needed
Either you have the correct stuff or not spot on. No time to go back to the store.
Ditto the setup. Either it is there spot on or not
Decide if you believe in the OEM ratings or not. If not, then do whatever. If so,
then read up and learn how it works and the ratings numbers vs your actual
Check your TV Receiver rating label. There will be two numbers. One with a WD Hitch
and other without (weight carry) vs your actual tongue weight
That video highlights bow wake effect. The trailer was not swaying until it
got out of the bow wake, or when that person met Mr Murphy...
Too late to slow down and the only hope for that driver was as mentioned...touch
the trailer brake controller to turn on the trailer brakes and *NOT* braking
the TV
