- DinTulsaExplorerI weighed with the truck ready to camp minus people, then weighed with the trailer hooked up ready to camp minus people. I've never read where the front should be heavier when a trailer is hooked up.
- IDoMyOwnStuntsExplorerIt really sounds like you do have it set up correctly with the weight properly restored to the front axle. I wouldn't worry about it unless you do get close to the 5100 rating, which I doubt you will. If you feel more comfortable, go ahead and take a link off and see how it drives. When I weighed mine, I noticed when I took a link off it only changed the front axle weight by 100 lbs. I also did mine with nobody in the truck but loaded for camping.
- DinTulsaExplorerThank you, I'll pull a link and see how it drives, if I don't like it I will add a link when I stop for fuel. I looked and the Front Axle is rated for 5600lbs, so I have a lot of room to spare on the front axle.
Thanks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
