DinTulsa's avatar
DinTulsa
Do passengers\ gear in the cab add equal weight to axles?
Has anyone weighed their truck without passengers then again with passengers? Does more weight go on the front or rear axle when the cab is loaded?
  • It depends on your cab and bed length. A standard cab with a long bed will put most of the driver/passenger weight on the front axle. A crew cab with short bed will more likely split the weight between the two axles.
  • you can just assume it's half and half, won't be enough off from that to make any difference.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Nov 02, 2025
