4x4van
Oct 20, 2020Explorer III
We, too, have a Camp Chef propane fire pit. At first startup, it gives out very little heat, but as the lava rocks heat up, it gets better. It does NOT put out as much heat as a wood fire, but part of that is due to it's smaller diameter, which is typically smaller than a normal wood campfire. If it's a mild evening, it works fine, but if it's cold, it just doesn't put out the body-warming heat that a typical campfire does.
There is a "fix", however. I replaced the stock fixed regulator with an adjustable regulator that goes up to 5psi (standard is 0.5psi, I believe). Although I never use it that high (it gives a 4'+ high flame!!!), I do often turn it up to about 2psi.
Looking for advice before your next adventure? Look no further.25,208 PostsLatest Activity: Aug 27, 2026
