opnspaces's avatar
opnspaces
Navigator III
Oct 19, 2020
Do propane fire pits put out any heat?
I like the heat and ambiance of a good wood fire when camping. But after more than 35 years of camping I'm finding that I'm starting to not enjoy constantly moving around the fire pit to stay out of the smoke. So I've been considering a propane fire pit, but I'm concerned about the heat output.
What are your thoughts? Do the propane pits put out a decent amount of heat compared to a modest wood fire?
  • Mine doesn't put out enough heat compared to the amount of propane it burns through.
  • We have a gas firepit in our backyard, quick simple fire to sit around with glass of wine.
    At the campground, much prefer wood as we do quite a bit of cooking over open fire, Oak firewood.
    A Propane firepit would have to be quite small to be considered portable as Lava rock is dense.
  • Fire is fire I would think. Perhaps the glowing wood embers contribute to more heat, at the expense of all the nasty smoke.
  • Kind of hard to make stick biscuits over a gas fire? Or Smores either.
    The RV park where we “snowbird” doesn’t allow open wood fires but propane fire bowls are okay. Ours will burn for 5-7 hours (5gl tank), with a medium flame. It’ll burn your boots if you’re not careful ;)
    www.walmart.ca/en/ip/outland-firebowl-portable-propane-fire-pit/6000188246998#:~:text=Perfect%20for%20outdoor%20recreation%2C%20the%20standard%20Outland%20Firebowl,of%20a%20cozy%20campfire%20with%20you%20anywhere%20outdoors.
    EDIT: I made your link clicky so it doesn't break the page.
  • We have a camp chef portable fire pit. The flame is adjustable and yes it puts out a lot of heat. Fire is fire. On high it does consume a lot of propane. We love ours, easy to set up, easy to light easy to put out and can be used in conditions that a natural fire can't - like wind.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Does a fire give off heat: YES does not matter if propane or wood.
    HOW MUCH.. Well that matters more on the size of the fire than the fuel.
  • We have a propane fire table at home. While the flames give a nice ambience to the patio, they are a waste of Propane!
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 11, 2026
