wa8yxm
Jan 07, 2014Explorer III
A standard Atwood or Surburan RV furnace adds moisture to the air OUTSIDE the motor home since it is a byproduct of combustion.. It only adds HEAT inside, if you need humidity you will need either a vaporizor or humidifier to add it. I use both when in the desert, plus saline nasal spray or .. Well, it's not fun.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 16, 2026
