full_mosey
Jul 19, 2013Explorer
restlesswind wrote:
Our fifth wheel.(see sig)
GVWR 14,900
GAWR 14,000
"G"rated tires 3750# per tire 15,000# total
US made GY
More than adaquate
Not picking on you, but 1000/14000=7% safety margin.
The unanswered question is "At what psi are your tires overloaded?".
I have a single axle TT, have been to the scales, and my heaviest wheel is 1060lbs. The tires are rated at 1360lbs at the 50psi max. I can run anywhere from 35 to 50psi per the tire load/psi tables published by the Tire and Rim Assoc. I have a 22% safety margin at 50psi(300/1360).
Your 7% is pretty good compared to some of the posts I have read.
If we all wait until the tire failure, we will be in no position to choose replacement tires!
HTH;
John
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 16, 2026
