restlesswind
Jul 20, 2013Explorer
full_mosey wrote:restlesswind wrote:full_mosey wrote:restlesswind wrote:
Our fifth wheel.(see sig)
GVWR 14,900
GAWR 14,000
"G"rated tires 3750# per tire 15,000# total
US made GY
More than adaquate
Not picking on you, but 1000/14000=7% safety margin.
The unanswered question is "At what psi are your tires overloaded?".
I have a single axle TT, have been to the scales, and my heaviest wheel is 1060lbs. The tires are rated at 1360lbs at the 50psi max. I can run anywhere from 35 to 50psi per the tire load/psi tables published by the Tire and Rim Assoc. I have a 22% safety margin at 50psi(300/1360).
Your 7% is pretty good compared to some of the posts I have read.
If we all wait until the tire failure, we will be in no position to choose replacement tires!
HTH;
John
Actually,I think it's a little better than 7%. Figuring pin weight at 15% of GVWR (2,200#) leaves 12,700 on the axles that are rated at 14,000.I run the tires at 110psi
I'll finish the math for you.
You have:
1. 1300/14000 safety on the axles, or 9.3%.
2. 2300/15000 safety on the tires, or 15.3%
You should keep your tires at the max psi to maintain that 15%.
If you want more tire pressure flexibility in maintaining that 15% safety, start looking for more tire.
HTH;
John
Thanks John,The next set of tires will be H rated with new 17 1/2 rims.$$$$$!
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 16, 2026
