oughtsix's avatar
oughtsix
Does my 2006 Duramax need a brake controller?
I am going to pick up our new to us 2006 Coachmen Captive 26ex tomorrow. This will be my first travel trailer. Do I need a brake controller in my 2006 Crew cab long bed Duramax? My Duramax already has the round 7 contact plug on the back of it.
Are brake controllers an added convenience for controlling and adjusting the braking force applied by the trailer brakes? Or are brake controllers a necessity to make the trailer brakes actuate at all? If brake controllers are a necessity does my Duramax already have one built in? (I have towed a large equipment trailer with my Duramax before and the trailer brakes worked properly.)
  • Did the large equipment trailer have "surge" brakes? The surge brake operates via the inertia of the trailer and the deceleration of the towing vehicle and is NOT connected to or operated by the towing vehicle. No controller required. If there was not a surge brake system on the trailer then the towing vehicle either has the GM brake controller as noted in the photo above or there has been an aftermarket brake controller installed. The aftermarket brake controller should be mounted under the dash in a place that easily accessible from the drivers seat,
  • So you own and you drive the truck but you don't know if you have a brake controller?
  • Most states have a requirement for brake controllers if you tow a trailer beyond a certain weight limit. It's good to have one for any weight trailer just for added safety. I would add one if your truck didn't come with one.
    The heavy equipment trailer probably had a built in brake controller. It sits on the tongue and uses motion sensing or electrical input from the brake light connection to apply the brakes.
  • The equipment trailer definitely had electric brakes not surge brakes.
    Thank you for the quick replies and the help!
  • Unless you installed one in your 06 Duramax...you will need to install an aftermarket one..NO 06's had a factory installed BC.
    Suggest a Prodigy. Mine has worked flawlessly since I installed it in my 06 DA when it was new.
  • RoyB's avatar
    RoyB
    Explorer II
    The GM TRUCK BRAKE CONTROLLER will look similar to this google image photo
    If your 2006 Duramax GM Truck has a built-in BRAKE CONTROL you will find the BRAKE CONTROLLER similar to this install...
    If you don't see one of these thumb controller slider switch units on your dash usually installed around your legs in arms length then you will have to install one. Prodigy is a popular brand BRAKE CONTROLLER.
    Roy Ken
    My 2007 Chevy did not have a built in brake unit so unless someone put one on the truck I would say the equipment trailer had a surge brake not electric brakes.
  • If you previously towed a trailer and the brakes actuated, I would guess that you have a controller, unless the trailer was activated by pushing against the ball.
    bumpy
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 22, 2026
