mowermech
Apr 01, 2014Explorer II
If the IGNITION is on, chances are the odometer will register the miles towed.
If the switch is in the OFF, NOT LOCKED position (if it has such a position, some newer cars don't) the odometer probably will not register the miles towed.
If the switch has to be in the ACCESSORY (ACC) position, the odometer probably will not register the miles towed.
If it has a mechanical speedometer/odometer, the miles will register regardless of switch position. It is VERY unlikely that it has a mechanical speedometer. Nearly ALL vehicles today have an electronic one.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
