- dieseltruckdrivExplorer II
Dutch_12078 wrote:
This is exactly correct.
A "freeze test" is not a good way to test RV antifreeze. The propylene glycol and water mix it's made with will in fact freeze at some point. The difference compared to straight water though, is that the PG/water mix does not expand to cause damage when it freezes. - Dutch_12078Explorer IIIA "freeze test" is not a good way to test RV antifreeze. The propylene glycol and water mix it's made with will in fact freeze at some point. The difference compared to straight water though, is that the PG/water mix does not expand to cause damage when it freezes.
- ktmrfsExplorer III
joelc wrote:
I am not at home base now, but I use it in my washer which is in my shed when the temps drop. I don't know if it has a expiration date on it. Mine is going on 2 years old and I know that it was good at 1 yr when used last year. Good question. Just thought of something. Take a cup put some in it and see if it freezes in your frezzer?? If it does it goes bad.
be careful. Many of the RV antifreezes will turn to a slush. It won't freeze solid and expand but it will become slushy. So if it does that in the freezer, it doesn't mean it is bad. That's just the way it is. - joelcNomadI am not at home base now, but I use it in my washer which is in my shed when the temps drop. I don't know if it has a expiration date on it. Mine is going on 2 years old and I know that it was good at 1 yr when used last year. Good question. Just thought of something. Take a cup put some in it and see if it freezes in your frezzer?? If it does it goes bad.
joshuajim wrote:
Seeing as how vehicle manufacturers recommend changing coolant between 100,000 and 160,000 miles which might correlate to 10 years of severe duty, I don't think I would worry much about some virgin coolant in a jug.
well, rv antifreeze is entirely different than vehicle antifreeze,
RV is either propalene glycol or ethanol, vehicle antifreeze is ethalene glycol, very poisanous, along with other additives, and it is a sealed system.
But a sealed or even open rv antifreeze jug that has been kept capped should be good for decades IMHO. - joshuajimExplorer IISeeing as how vehicle manufacturers recommend changing coolant between 100,000 and 160,000 miles which might correlate to 10 years of severe duty, I don't think I would worry much about some virgin coolant in a jug.
- docsouceExplorer II3X on what D3500ram said. I still have some of the blue -100 degree Quick Silver stuff that I bought just before selling my boat a couple of years ago. I use it for the sink traps, put some in the gray and black water tanks. Be all gone this year. New RV antifreeze is just to inexpensive to chance.
- JimK-NYExplorer IIIt should last for years if not decades. If it has gunk in it, that was not something that happened without some human intervention.
- BumpyroadExplorer
d3500ram wrote:
If you are concerned about any funk in it, just use it in the toilet and traps and get the fresh stuff for the domestic water supply.
a winning suggestion.
bumpy - kellemExplorerI would use it but if you feel uncomfortable, your looking at roughly 12 bucks for 2 gallons of RV antifreeze.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
