msmith1.wa wrote:
I didn't see any one suggest an extend a stay, or stay longer kit.
Stay Longer
It will allow you to connect a propane bottle to the motorhome system.
way2roll wrote:
Maybe I am missing something but this seems like it's being made overly complicated. If the existing tank is bad, and if it really takes forever to get a replacement built in, a simple device like an "extend a stay" hooked to an LP tank you can get at any grocery store will work. I am not sure what RV you have but I see LP tanks of varying sizes everywhere. Are you saying you can't find a single one to replace the existing tank? Even if the mounting hardware had to be fabricated by a welding shop, it doesn't seem that hard or expensive,
And even before that part of one of my posts
Back when Dad was full time, he had a valve system (Extend-a-Stay?) so he could put a larger tank outside, have a truck come by and fill it. He kept the onboard tanks hooked up, but turned off. (Get up, turn on tank, light furnace not good. Wake up, discover totally out even worse)
