Brownleaf's avatar
Brownleaf
Doing without propane
I eat alot raw and enjoy use of the microwave. For heat would there not be possible alternatives for a small 24 ft. motorhome? I have never tried anything but propane and would want something very safe. I guess there would be no other options for "dry camping" Long range I will get a new propane tank just exploring alternatives. Doug
  • I'm using this style of heater, they say 1500W but they really draw ~1,000W on high and 500W on low according to my killowatt and smart plugs. On a 30A you could run 2 on high easily enough. If it gets really cold they might or might not be enough to keep it comfortable, you might want to have a buddy heater available for the very coldest nights. Also note they'll do nothing to keep your tank warm, my trailer was winterized back in November and I've been carrying jugs of water in and using the facilities in the house.
    As far as temps, 10F is the coldest day I've seen without any propane use, that was after I got the 3rd heater. My trailer stays at 45 at night and then starts warming up to 72 90 minutes before my work day starts, 30 minutes before the propane furnace is set to 65, so it only comes on if the electric hasn't raised the temp from 45 to 65 in 1 hour. At anything below 10 degrees that was happening most days with 2,000W of electric, like I said with 2,500W it's only happened once that I've seen.
    Basically at least in my trailer with Reflectix in the windows and the vents stuffed with Camco reflective pillows I'd be fine down to 10F easily, below that I'd want a supplemental source of heat.
  • afidel,
    Did you happen to note the voltage under load when measuring the wattage on the heaters?
    I love my kill-a-watt and my watt meter.
  • pianotuna wrote:
    afidel,
    My voltage is generally around 123-125V, according to my smart switch this month it's been 120-123.3V at the device for the heater in my living room.
  • I know I'm late to this topic, but if I were looking for something as an alternative to propane, and electric didn't do it, I'd look into the no-name Chinese diesel heaters that a lot of people are touting. They can throw out quite the BTUs for the relative small size and power usage (around 3-4 amps), and exhaust the stuff outside.
    If I were putting in a furnace, and could use propane, I'd go with a vented Platinum Cat, as it uses relatively few amps to keep a rig warm.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
