Brownleaf's avatar
Brownleaf
Doing without propane
I eat alot raw and enjoy use of the microwave. For heat would there not be possible alternatives for a small 24 ft. motorhome? I have never tried anything but propane and would want something very safe. I guess there would be no other options for "dry camping" Long range I will get a new propane tank just exploring alternatives. Doug
  • IH cooker looks interesting but no good for dry camping. Right now my onan gen is no good so no genset either. Depending on the weather maybe I would not need a heater on some nights with this global warming. I do camp between Dec and March only. But only in very southern desert country. Doug
  • Are you in a situation where you have an under-floor propane tank that is bad and need expensive replacement so now is the time to ask this question?
    OR new bbq tank for $40 full?
    Keep the propane onboard for the heat, that furnace is so easy and already safe.
    Use the stove, it is already there, yes it takes a little longer, but no need to run a generator. If you like cranking a generator to heat a plate then fine too.
    The Buddy heater will be maxed out for a 24 foot camper, but use at night in a closed bedroom with window cracked for safety and a CO alarm you will be fine.
    Buddy does put out humidity so room will be more humid and you will get condensation on walls that can lead to mold if used a lot.
    If you were building from scratch it is one thing, but you have an RV built for propane, use it. what about the fridge, you don use a fridge?
  • Not that I can think of unless you install a little wood burner and heat with wood or have enough battery capacity to heat that way which would be very expensive.
    You the guy with the rusted out LP tank?
    Have you considered a storage area in the RV that you could modify to accept 20lb or 30lb portable LP bottles? Basically just needs to be sealed from the interior with open air ventilation. Piping and hoses shouldn't be too much of a challenge.
    Another option that would use electricity, but near as much as electric heat could be a pellet stove? Quick check, saw a wall mount pellet stove that was 27x36 x 12" deep. Heats 1000sf, so you could run it very low to heat a couple hundred sf?
Looking for advice before your next adventure? Look no further.25,114 PostsLatest Activity: Feb 22, 2025
