abc40kids's avatar
abc40kids
Dolly towing
My buddy is gonna tow his 95 Wrangler 4x4 on a tow dolly behind his RV. It’s a manual, is he ok in neutral or will there be damage? Thanks
  • ferndaleflyer wrote:
    someone needs to explain to me how it is all right to tow it 4 down with the drive shaft in but you need to take it out to tow on a dolly. Am I missing something here?
    Slap that puppy in neutral and go. 1995 Jeeps, assuming they're 4WD, only need to be put in neutral. Taking off the drive shaft is only to get you dirty, and make you manly looking cuz you own a Jeep. It's recommended you don't shave for three days prior to leaving. :)......Dennis
    95 Tow guide
  • someone needs to explain to me how it is all right to tow it 4 down with the drive shaft in but you need to take it out to tow on a dolly. Am I missing something here?
  • Yes, if he removes the rear drive shaft the Jeep can be towed with the front wheels on a dolly with no problems. The transfer case does not have to be in Neutral, the transmission does not have to be in gear.
    Seems to me, though, that considering the fact that a 5000 lb. capacity towbar is available from Walmart for less than $175, (that is what I use) or from Harbor Freight for less than $100, and magnetic tow lights are available from the same sources for $20 to $50, and a Jeep can be towed 4 down with no problems (read and follow the instructions in the Owner's Manual), it doesn't make sense to use a dolly.
    But, again, it can be done with the rear driveshaft removed
  • the remco page only has info on 1996 and newer vehicles. if i were him i would..
    - check the owner's manual
    - call Jeep...not a dealer but the mfg
    - contact Remco by phone.
    i wouldn't gamble. without a direct answer i would not proceed.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
