wa8yxm
Jan 25, 2023Explorer III
There are a few parts that are suspect
First is there 12 volts to the fan assembly (Use a test light not a volt meter please) (Bright is good, Dim is not)
The 4 position switch (OFF LOW MED HIGH)
The Thermostat
The Lid Switch
You can bypass the lid switch and the T-Stat to test.
Not sure how the 4-pos is wired. so not sure how to bypass.
The Thermostat
The Lid Switch
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
