dave17352
Mar 23, 2017Explorer
My propane fridge works as good as they can. My temp is 7 below in the freezer and the fridge is right at 37. That's as of last night. The installers put the curved metal in at the top and it draws really good!
All of that said when it gets really hot like 95 plus or driving in really sunny hot weather it suffers. When and maybe before mine dies it will be replaced with a 12 volt compressor fridge. They operate like a residential fridge and can keep your food nice and cold regardless of outside temp.
If you have a fridge that won't work and your venting is correct I would suggest you look into a nova kool or similar replacement 12 volt fridge. They make them to fit almost any standard opening. They also have the advantage of not needing to be level to operate. JMHO
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
