kjandjosh's avatar
kjandjosh
Door issues
Ok I have a 2014 Coachmen Freedom Express 292BHDS
I am having issues some of the time opening the door.
It seems like the screen door is getting hung up or something.
and before anyone says it. Yes it is unlocked and yes i am pulling on the handle.
Anyone have this type of issue before?
and tips or tricks?
  • Is it setup? And if so, Do you have it sitting on the stabilizers instead of the wheels? In other words. Did you use the jacks to lift one side to make it level. Instead of raising it with blocks under the wheels? If that is the case. You could have put the frame in a bind, which put the door in a bind, and would make it hard to open.
    Don't know if you did. But the stabilizers are not for leveling.
Looking for advice before your next adventure? Look no further.25,182 PostsLatest Activity: Jan 25, 2026
