subcamper
Jul 24, 2014Explorer II
eric1514 wrote:
Sometimes you need to do more than lube it. Close the door slowly and look at what's rubbing or interfering with a smooth closing. Take a magic marker and "paint" different parts and see where the marker is rubbing off. Study it closely.
On my MH, the jamb started to bow in towards the latch on the door; the jamb and the hinge sides were no longer parallel. I have no idea why. A straight edge along the jamb confirmed this. The door latch was hitting on a "flat" and not on the sloped face. I spread the opening slightly and now it closes with one finger.
Good Luck,
Eric
My 2002 TT had the same problem. For whatever reason, the clearance between the door jamb and the door edge reduced slightly, causing the latch to hit on the flat part. This required either slamming or pulling the release handle slightly while closing. In my case the jamb was not bowed.
To fix the problem, I removed the two screws at the door edge that held the latch in place. I installed a couple of washers inside the door between the door edge and the latch. This retracted the latch into the door slightly (1/8" or so) and now the latch hit the striker plate on the sloped part and shut easily.
Steve
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
