davosfam
Aug 05, 2014Explorer
hook47 wrote:
Had the same issue of a difficult to close door. Had sprayed silicone, didn't last long nor really fix the issue. Tried dry lube, the spray kind with PTE in it. Made it vastly worse. Then tried Blaster 12oz Garage Door Lube and problem solved. Now one finger will close it with hardly any effort at all. I just sprayed the heck out of the latch mechanism with this stuff, didn't have to do any cleaning first. If you read the label it dries without being tacky. Great stuff.
Got this and it worked like a charm! Thank you!
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
