David_homen's avatar
David_homen
Dragging a Jeep Unlimited around corners
First Post. I have a 31 foot Jamboree Sport. It is on the Ford E450 chassis and has the 460 motor in it. I have towed a Wrangler X soft top with no issues. I now have a Jeep Unlimited Rubicon that I tow. Here is the issue. At higher speeds, it seems that I am Dragging the Rub around corners, especially longer corners. The coach has almost come to a complete stop with not enough power to tow. The tow seems to do quite well around the neighborhood with sharp turns at intersections. I have verified setup with leaving the key in the On position and moving the steering wheel back and forth and verify that the front wheels actually move when going around corners in the neighborhood. Can not verify if they are turning on the higher speed corners.
It also seems that when it finally does start to catch up, I have to move the coach steering wheel opposite to the turn and catch up.
Has anyone else experienced this.
I have a Roadmaster Falcon 2 tow bar that I leave on the coach and the Rube has the Roadmaster hook up with an extension that supports the Blue Ox ends on the Falcon 2. That is a Long Story starting in San Diego. I can describe it further if needed.
The Rube weighs in at 4650 with a full tank of gas. I don't put anything in it when towing.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 22, 2026
