buc1980ExplorerApr 18, 2016Drain master hoseAnybody use this sewer hose which cost 130$.Looks good but how you use it on regular bayonet connection.You got to modify(CUT) the FW CONECTION TO MAKE IT FIT.
buc1980ExplorerApr 18, 2016Check the internet and you will see.It looks good and it do the job better
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,208 PostsLatest Activity: Aug 27, 2026
Related ContentHouse battery drainQuestion: Drain hoseFrig. drain hose ???Quick connect exterior shower hose doesn't connect.Drain master hose
