buc1980ExplorerApr 18, 2016Drain master hoseAnybody use this sewer hose which cost 130$.Looks good but how you use it on regular bayonet connection.You got to modify(CUT) the FW CONECTION TO MAKE IT FIT.
fj12ryderExplorer IIIApr 18, 2016A hose is a hose. If it drains and doesn't leak, how can it "do the job better"? Plus you have to modify to make it work? No thanks.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,208 PostsLatest Activity: Aug 27, 2026
Related ContentHouse battery drainQuestion: Drain hoseFrig. drain hose ???Quick connect exterior shower hose doesn't connect.Drain master hose
