buc1980ExplorerApr 18, 2016Drain master hoseAnybody use this sewer hose which cost 130$.Looks good but how you use it on regular bayonet connection.You got to modify(CUT) the FW CONECTION TO MAKE IT FIT.
downtheroadExplorerApr 18, 2016You can buy the cam connection fitting and use whatever hose(s) you already have.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,208 PostsLatest Activity: Aug 27, 2026
Related ContentHouse battery drainQuestion: Drain hoseFrig. drain hose ???Quick connect exterior shower hose doesn't connect.Drain master hose
