buc1980ExplorerApr 18, 2016Drain master hoseAnybody use this sewer hose which cost 130$.Looks good but how you use it on regular bayonet connection.You got to modify(CUT) the FW CONECTION TO MAKE IT FIT.
rockhillmanorExplorer IIApr 18, 2016:HIt's the same hose material as a Rhino hose only difference is an end fitting with an added plastic handle on it.Poop's gonna run out of the same way it does with a Rhino.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,208 PostsLatest Activity: Aug 27, 2026
Related ContentHouse battery drainQuestion: Drain hoseFrig. drain hose ???Quick connect exterior shower hose doesn't connect.Drain master hose
