GordonThree wrote:
That's an expensive stinky slinky. What makes it better than a Rhino hose?
Since you ask.. IF the Drain Master is the one I believe it is check out the warranty. The Rino Hose lasts about 5 years tops in full time use.. The Drain Master is advertised as the LAST hose you will buy..
Why.. If it wears out.. they replace it. And that is what makes it better than all others.
I'm using a Valterra Smart hose when I get back on the road.. I really like the feel of it, it came with adapters to fit my RV (It uses the "Fire hose" type Cam Lock connectors, not twist on, First time putting it together was .. hard, works better the 2nd time)
But where I'm parked now I'm using the one the dealer put in the Righ FREE 11 years ago next month.... Yup, you see it is the precise length I need and believe it or not has outlasted all other hoses (I don't often use it though) The "Smart Hose" (plus a couple of Camco Hoses) are in storage.
