bdpreece
Nov 13, 2016Explorer II
If your charge wire from your motorhome is working correctly you should have no problems with the battery discharging. One of the problems I found was not only did I need to run a charge line but I had to run a dedicated ground line from the motorhome to the toad. Using the hitch connection for ground did not work well.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
