Golden_HVAC
Dec 19, 2015Explorer
Have you measured the voltage at the battery? At the battery while under load?
Most furnaces will ignite at 11.6 volts, and that is a battery that is about 20% full. Your engine alternator is probably putting out about 14.5 volts and will allow the furnace to run while trying to charge the battery. Once the engine is off, typically a 'full' battery will have between 12.7 and 12.8 volts, while one just off the charger might have as much as 13.3 volts for a 1/2 hour, then will settle to 12.8 volts.
Your RV will use 1.2 amps per hour just to run the CO detector, propane monitor and refrigerator. This is enough to discharge a full battery in about 2 days, even with no lights running. Add a 6 amp per hour furnace, and the battery can go dead in a few hours.
Are you plugged into shore power? If you are, then the converter / charger should be supplying the power to keep the battery full. Check for a tripped GFI someplace that might be supplying power to the converter. If there is no power to the receptacle it is plugged into, try running another extension cord from a good power source to the charger. Even if you do not have a digital volt meter, you can look at your gauges and see if battery reads 1/3 or full. IF it reads empty, and you are on shore power, suspect a problem with your converter.
You have a 1984, probably is a converter, not a modern battery charger. You would be much better with a modern charger, but they are around $300 - $400. They can put out up to about 45 amps, and accurately charge the battery. However the prior owners might have already upgraded to a charger. You will need to look for it, and report it's model number if you have low battery voltage and problems.
Good luck,
Fred.
Good luck,
Fred.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
