rickhise's avatar
rickhise
Drop commode seal question
In my unit my commode has been swapped out. It’s a full size Dommetric sorry about
Mis spell. Straight drop. To the issue I need to replace the seal around the ball. Question can this be done without removing the commode from the floor.
The unit will drain dry after u partially fill.
Previous owner told me he had a difficult time getting the commode to seal to the wax
ring.
Hoping to replace the ball seal without lifting the commode. Thanks
  • wvcampers wrote:
    Dometic says to put hot tap water in the bowl. I have done this twice and both time the seal started holding water again.
    No doubt that may work but there is a point that the seal needs to removed, cleaned, lubricated and replaced. There may also be a time to simply replace the seal.
  • Dometic says to put hot tap water in the bowl. I have done this twice and both time the seal started holding water again.
  • Maintenance on the 300 series Dometic is very easy. Simply push down on the go pedal and pull out the rubber seal. Clean it up dry it and add a layer of Vaseline to bottom side of seal. With the ball closed push the seal in place. While seal is removed give the ball a good cleaning.
  • If a Dometic 300 series toilet, you don't need to remove the toilet to replace the rubber gasket but you probably don't need to replace it anyway. I had the same issue. I pushed down on the gasket all the way around and then cleaned it thoroughly with soap/water. Then I applied petroleum jelly (Vaseline) to the underside of the gasket (the side that comes in contact with the ball). That did the trick and I haven't had any further issue.
  • Wax rings are not recommended for RV toilet use. The normal vibrations while underway can spread the wax destroying the seal. The toilet manufacturers supply a closed cell foam seal made for the purpose. Without knowing the model of your toilet, it's difficult say what the flush ball seal replacement requires. On my Thetford Aqua Magic Style Plus porcelain bowl toilet, changing the ball seal takes about 15-20 minutes without lifting the entire toilet.
  • Which MODEL???
    Some the seal can be removed/replaced w/o having to disassemble toilet (can be done w/o removing toilet)
    Some you have to disassemble toilet. (Easier to do by removing toilet)
    WAX Ring....
    RV toilets use a 'foam gasket' between toilet and floor flange
    So WHAT MODEL?
    Many times seal/ball just need a thorough cleaning/lube job
    Turn water off
    Open Ball and using your hands (you can wash them afterwards!) go over the seal flexing it/feeling it/removing any mineral/stuff on it.
    Then put some dish soap in your hand and scrub seal top/sides/bottom
    Do same with ball ....clean it across top surface
    Then rinse seal/ball clean
    After rinsing all soap off lube up seal & ball with plumbers grease (OR Olive Oil)....no vaseline ---it is sticking & can attract crud
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
