hasheel's avatar
hasheel
Dsi water heater
My Atwood 6 gallon gas only water heater, kicks on. But it does not stay on long enough to heat the water sufficiently. Any ideas?
  • Flame MUST engulf spark electrode when it lights off
    Spark electrode needs to be clean-----emery/crocus cloth
    Ceramic on spark electrode if cracked will allow ground tracking...wipe down using a rag with silicone sprayed on it
    Contacts on high tension wire at board or electrode must be clean/tight
    Flame has to 'prove' it lit
    It does this by flame ionization which actually generates a millivolt signal that goes back to circuit board.if circuit board doesn't get this signal it shuts down gas valve
  • Is there actually any water in it? Did you pull the relief valve and see if water came out.
