valhalla360
May 24, 2019Navigator
time2roll wrote:
Check your plug at the pedestal for heat.
Probably worth taking a look at the back of the breaker panel and all along the cord.
30amp is only rated for 25amp continuous, so you are really pushing the limits. If everything is in perfect condition and the voltage in the park is good, it can work.
Voltage can play a role here. If you are in a park with high voltage (but within nominal specs), it can work but if voltage drops, it will become a problem. Watts = Volts * Amps...so to maintain the same power (watts), if the voltage drops the amps will go up. If you are lucky, the breaker trips.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
