Cummins12V98
May 28, 2019Explorer III
myredracer wrote:
Drawing high amps (on 30 amp pedestal) for extended periods can result in an overheated plug to pedestal connection. There are even some that say you should never draw over 80% of 30 amps, 24 amps (which I disagree with). Two AC units (rated @ 12.5 FLA) is already at 25 amps and that's *if* the voltage is near or at 120 volts. Add in the converter draw, fridge on electric, TV and you're over 30 amps.
To size a "main" breaker by code calculation, if you have AC units rated at say 12.5 FLA and were drawing 5 amps from the converter and no other loads, you would require 12.5 amps + 5 amps + 20 amps (required breaker size for startup), you would need a breaker rated for min. 37.5 amps. You would then need to go to the next available size up, or 40 amps.
Doesn't matter *if* it seems like two AC units are working fine, it IS causing damage to the motor windings which degrades the insulation over time and shortens the life of AC units. The voltage at the AC terminals will be somewhat less too.
The idea is to turn off all high draw items and the two AC's on 30A will be fine. Yes low voltage could be an issue! There are variables in all situations. The 30A plug should be of good quality and it's receptacle on the pedestal.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
