map40
May 31, 2019Explorer
Depends on your ACs. I have 2 Atwoods and I can run both with no problem, along with the converter, light and TV. Generator or Campground. Both units are rated at 12.5A and they are 13.5K
The Fleetwood units that come with 30 Amps and 2 ACs use the High efficiency ACs that consume only 9 amps. My 36ft Fiesta LX did 106K miles running 2 ACs on 30 amps, never a problem.
As you see, the answer to "Can I run 2 ACs with 30 amps?" could be depending on a lot of factors.
I say "Yes you can, just check voltage and/or temperature on the plug"
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
