lastword's avatar
lastword
Ductless AC instead of roof mounted AC
In addition to my roof repairs I am replacing the AC unit on my trailer.
Does anyone have any experience with the Mini Split Ductless AC Heat Pump reliability on an RV? I have seen installs on youtube and they all claim no problems with it. I worry about the bouncing going down the road causing a freon leak, But when I look at the construction of both roof and ductless I don't see significant difference in the build quality or design. So I'm thinking there should be no problem.
Planning to mount the outdoor unit and a generator to a welded platform on the rear of the camper and install a small brush guard and backup camera, and make sure the line-set is insulated and supported properly.
The unit I am planning to use ($460.00 delivered).
https://www.ebay.com/itm/12000-BTU-15-SEER-110V-Mini-Split-Confort-System-Ductless-AC-Heat-Pump-110V/303081116734
Says its good to 600 square ft, I have a little over 200, heating and cooling.
I have worked in manufacturing and installed and maintained many AC units. I have all the tools vacuum pump and hoses/gauges.
Thoughts? Sanity Check!
  • I've seen folks use mini splits I "tiny homes" and converted cargo trailers with good results
  • lastword wrote:
    Mini split Update
    Overall I am quite happy with the performance of the Mini split
    Would love to see a photographic overview of the installation.
  • Photos photos photos otherwise this does not make as much sense.
    Glad it all worked. I did a lot of research on alternatives to the roof unit.
    For the amount you spent on this device, why did you not just put on a roof AC and be done with it? A roof unit is built for the road and you are experimenting as if a house unit will hold up over the years of driving…
    Ebay finds are maybe $600-800 or a used one around 400. Hint, I have a used Penguin that is perfect in every way except wont run off a 2200 gen.
  • The torque values should be in the installation manual. Those flare fittings are the weak point at this time. There is a whole industry trying to produce an easy to use, reliable tool that will consistently produce a non leaking flare. If it was leaking, and you just tightened it down, it's probably going to leak again at some point.....
  • As far as leaking flared joints, 45 degree conical copper washers have been used for years to seal between leaking 45 degree fittings. Several years ago an a/c auto shop installed 2 in the a/c lines in a vehicle I owned to stop leaks at the 45 degree joints. I and the next owner who is a friend never had another a/c leak.
  • I've used the copper washers mentioned above, and never a leak again in over 20-years.
  • Be careful messing around with the fittings while the unit is running, R410a systems can have operating pressures above 450psi.
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
