wa8yxm
May 23, 2014Explorer III
There are two main makers of power awnings, Carefree of Colorado and A&e (Dometic/PowerGear/Kwikee/Atwood)
I do not have a Carefree but I do have an A&E
Per the owner's manual there is a screw (or two) in the forward most arm, you remove this and you can roll it up by hand, NOTE there are actually 3 different screws on the one I worked on.. TWO and the motor turns free so you can roll it up, the third is the bolt that holds the end bracket on the arm.. Removing the two so the motor turns free breaks a wire, Removing the one makes it much harder to do the wind up.
Since the motor is not working, Breakign the wire not a big deal
Second: You need to replace at least ONE of the screws (Bolts actually) when the thing is rolled up.
This is all in the manual.
I Strongly suspect Carefree is much like this, but I am 100% sure it is in one part: This is all in the manual
You can go online and downlaod the manual from the maker's web site.
PAGE 2:
IF the controller (not the motor) fails
In your owner's manual bag there should be a long read/black wire pair with a FLAT 2 connector on the end (A&E at least) if it's not there COMPLAIN to whomever you purchased from.. There is a matching plug near the motor (Unplug it before you wind up by the way).
Unplug motor from wire leading up to it, plug into the "spare" harness and attempt to wind by hooking to a 12 volt battery known to be good (Car, Motor home, As long as it is known to be good) IF motor turns wrong way.> REVERSE connections.. YOu will hear a CLICK as it connects, if no click then it is the brakes not the motor (But same assembly) Oh at the time Rachel did the warranty work for the poor RVer I assisted with rolling it up due to pending windstorm a new motor was 400 dollars.. I think this was 2007/8 but not sure. She had to repalce the motor twice, turns out a bad switch and controller were burning them out.
PAGE 2:
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
