craz_z's avatar
craz_z
Dump Rage
Do You have dump rage?
You know the scenario weekend warrior gotta dump at the end of the weekend and the line is long.
I'm finding myself more and more irritated at the free dump stations. I only boondock and these stations are in bigger towns that are on my way home so I have no other choice. Closest dump station to me is an hour from my house.
I've been picking up a few handy tips as well to make it as fast as possible. However there is always these things that blow my mind when I pull up.
Usually I don't get too wound up but this one really got me, but after I really thought about it, it might actually make the process even faster.
So I come to the dump guy is unloading in front of me. I get my door up and my hose out and actually walk up and lay my hose down before my turn.
Guys are nice and then I see him and his friend pulling in a water hose i think it was a drinking hose no less attached to the nasty dump hose spigot hose. He proceeds to run it through the window and another 10 minutes goes by. I was next inline so I was patient as you have to be watching him unhook the water line with it turned on etc. Always good for a laugh.
Now there is a great line behind me at least 5 campers deep. This guy rolls up in a class A on the opposite side of the dump. I can see him putting on gloves and getting out when the first guy finishes his weird flushing procedure. The first guy in front of me was kind enough to actually move forward to put his gear away.(nice!)
So watching this other guy I KNEW what he was up too and I raced to get in position and get dumping. He's opened his bay door and pulls out his hose, I'm already hooked up an dumping at this point.
He says the worst part about camping is? I cut him off and said you know the line is way back there right. He says yeah but it'll just take a second. He knew I wasn't happy about what he was doing and I finished quickly and got outta there.
I know if i was next in line with this cutter I would have probably lost it on him.
I was trying to let him know its not right what you're doing with the long line of people behind me.
After I reflected awhile I kinda thought about something. It would only work in this type of dump. An island with enough room on both sides for the one dump. If you have 2 campers trying to dump. there is always the guy taking his time hooking up flushers putting gloves on and the other guy can be dumping so on an so forth. basically cutting the time down to only dumping and moving through the lineup faster. Of course it would only work if one is dumping an the other is setting up or tearing down.
But i see some of the most ridiculous things at these places I get anxiety dumping on a Sunday. Maybe the answer is time of day and time of week to avoid the dreaded dump station.
I've tried to develop a system for these types of places. They can really add a significant amount of time waiting on these clowns that take their time 3 deep can be an hour if everyone is flushing and doing god knows what else.
Be ready. Doors up hoses placed near ahead of time. dump. add some water down the sewer, pull away then collect your things so the next guy can move in. I try to be like pit crew at a indy 500 race. My record is 4 minutes from move in to move away.
Sorry for the rant but do you get DUMP RAGE?
  • I have a sewer connection at home, so I've used such a dump station only a couple times in the decade we've owned an RV. But I quite understand your pique. I've encountered plenty of self-absorbed inconsiderate entitled boobs many times in other lines. And there have been a few times when it was all I could do to not unload on one of them.
    But I do remember once, many many years ago, pulling into a busy gas station to tank up and finding myself behind a guy who tanked up, went inside, and evidently got a hot dog, took a dump, and chatted up the pretty young thing at the register until she finally kicked him out. By then, having waited about 15 minutes behind him at the pump (AFTER he'd filled up), I had gone around him, backed up within inches of his bumper, and started pumping, when he finally staggered out and was highly offended that I had him blocked in. I remember telling him I'd waited on him for 15 minutes, now it was his turn to wait on me, and I'd be done as soon as the tank fills and I go in to pay for it. No, he wasn't happy about it.
  • I can't decide if "two directions - one hole" is brilliant or just lame not to provide two holes and a lane from each side.
    I do tend to just roll on if there is no open spot. No rage... I roll.
  • I've made a bit of a science out of efficient and fast dumping myself.
    My sewer hose is stored in a fence post cover I installed at the sewer connection. It actually snaps in place.
    Flip the lever and it ejects the hose with a 90 already on it.
    (first hose keeps second hose secure in forward tube).
    When it comes to dumping, I don't "rinse" with fresh water. If dumping 30~60 gallons of soapy grey water doesn't flush it good enough, nothing will.
    I've also set up a way to flush the black without taking too much time (& if no one is behind me).
    I have installed a third valve where the sewer hose attaches.
    So I can dump the black, close this valve and let the grey and black equalize which forces 20~40 gallons of grey backwards into the black tank. This only takes takes 30 seconds or so.
    Then I dump the black again (now with grey water in it) and I always get a lot more TP and "stuff" out.
    Finally, I dump the last 20~30 gallons of grey which does a final "flush" of the sewer hose. Since the hose snaps into place, I don't even have to install a cover over it
    We also have a hose-powered black tank flusher but I only use that at campsites.
  • No other choice? Can you fix your home system to dump there? Is there a commercial dump at a R V park? Will the city let you dump at the treatment plant? There is always a choice.
    Nope ... never line up at any dump station and instead service my tanks at home using a waste macerator. :B
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 27, 2025
