CavemanCharlie
Dec 27, 2016Explorer III
theoldwizard1 wrote:CavemanCharlie wrote:
They do seem to get corroded battery terminals purdy quickly. Though cleaning them once a year seems to do the trick.
- Clean the posts and terminals with baking soda and water. Rinse well and dry
- Put a good gob of axle grease on top of the posts and spread it out at least 1/2" past the edge of the post.
Replace terminals- Put another gob of axle grease on top making sure to cover all of the metal.
After the 2nd year I had to add water.
You really should check the fluid level at least every 6 months, more often if you are in a warm area of have a lot of charge/discharge cycles.
I do clean them with baking soda and water. I will try the Axel Grease. Thanks !!!
It is hard to access my batteries so I check water levels once a year. I did not have to add any until the 2nd year. I suppose as they get older I will have to add more often.
I do not live in a warm area and I have never discharged them very far. I'm just a weekend camper with using 2 -125's Even running the furnace on a 40 degree night doesn't seem to draw them down very far. Then I go back home, plug them back in, and charge them right back up.
Love them. Everyone else I camp with is so worried about power and I can park anywhere for the weekend.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
