rn09's avatar
rn09
E-rate question
I just got myself an 2008 Tundra 5.7L with towing package. I believe tow max to 10,100 lb. The tires on them are showing their ages. Looking for replacement. I am also looking for TT around 5000 lbs dry.
Been doing some reading. Most said E-rate are good for towing. But how to look for the rate of the tires online. Like the link below. There is no indicates that about the rates: A, B, C, E......
http://www.discounttiredirect.com/direct/filterTireProducts.do?pgTires=0&vid=013200&yr=2008&cs=255&ar=70&rd=18&counter=0&fl=&sortBy=prca&fqs=true
Been gone for awhile since I sold my pop-up. All my posts are gone too??
  • Here is the link to Tire Rack's Bridgestone Dueler Revo's. Click on 'specs'
    TireRack LT265/75R16...what I have
    Mine is LT265/75R16E (load range E)....notice that it is now also referred to as
    load range 123/120R, which is the new designations. As the old ply rating too
    confusing to most folks.
    They have come down in price, as when I bought mine...they were $240 each...
  • rn09 wrote:
    snip...
    No, they are not gone. All posts older than one year are archived. Click here to see all your old posts. :)
    Barney
  • Few LT tires are made in C, D, and E range. There is simply no purpose. Find a quality LE tire in any load range. Running an LT C tire and 5-psi will be the same as running an LT E tire and 50psi.
    I like Tirerack's survey results. Top few tires in any given category will make almost anyone happy.
  • The letter codes are going away, as they are confusing to many...going
    to the number codes for load rating
    Letter codes signify the number of cotton plys (fabric embedded in the
    tire sidewall) and is very old. 'C' signifies 6 plys. 'D' signifies 8 plys
    'E' signifies 10 plys
    Today, cotton plys are no more and synthetic cords to make up the fabric
    Most today only have 1 - 2 actual plys or more, but can be rated 'E'
    (10 ply)
    Also needs the tire size in order to know it's ratings. A 10 ply (E)
    small tire will NOT have the same rating as a 10 ply (E) bigger tire
    This is the best tire/wheel/etc info site all in one that is easy to
    understand. Read up and then the other sites will make more sense
    Best Tire info site found to date
  • rn09 wrote:
    lanerd,
    Your link is as same as mine. I looked at the tire and don't see where they indicate the rate like A, B, C, E, D
    rn09, he was just providing a clicky link to the URL address that you didn't provide a clicky link for.
    that saves us from having to copy and paste to see what site it is.
    personally, if the OP doesn't provide a clicky link and just posts a long URL address that i have to copy and paste into my browser, i don't even bother looking.
  • rn09 wrote:
    lanerd,
    All of the tires in the clicky are P tires. P tires don't come in load ranges like our LT tires.
    IMO using a LT E at 3000-3400 lbs each on a truck with small semi float axles is not the best idea. Many 1/2 ton trucks wheels are not rated foe those pressures. The C or D tires make better sense/cents.
    LT E tires are best left to the 6200/9800 lb axles on our 3/4 and one ton trucks.
    I've tried load E tires on std duty 1/2 ton trucks a few times over the years and regretted doing so.
    Other have their opinion on E tires on std duty 1/2 ton trucks.
    Edit; changed wording
  • lanerd,
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
