Bobbo
Oct 15, 2013Explorer III
rockhillmanor wrote:
I pour several gallons of antifreeze in the fresh tank and turn on the pump until all faucets, shower and toilet run pink. Yes it takes a couple of more gallons but at only 6 bucks a gallon it is worth the small amount of extra money to be able to winterize in minutes without all the fuss.
Been winterizing my MH for 6 years now while sitting in the deep freeze of Wisconsin. And you won't see a post from me about leaks and damage the following spring. Actually you won't see me post about winterizing any more either.....Florida. :C
And no the water does not taste like antifreeze because it's put in the fresh tank. It takes the SAME amount of flushing come spring to clear it out as when you pump it thru the same lines from the outlet. And my pump is fully winterized by doing it this way also.
Except for the fact that I don't put anything in the fresh water tank I do this. I have a winterizing bypass. I turn 1 valve and stick a hose in the antifreeze bottle, then turn on the pump. Takes 2 gallons to do the whole RV.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 31, 2026
