dmshaull's avatar
dmshaull
Eaz-lift Trekker trunnion movement
I have a couple questions about the use of my Eaz-lift Trekker weight distributing hitch (part number 48703). I’ve had the hitch for about 2 1/2 years, and have not had any problems with it so far. (This is the only trailer/hitch I've used; our previous RV was a motorhome.)
1. After using the hitch recently, I forgot to loosen the activation caps before unhitching the trailer and storing the hitch. So I put the hitch back on the tow vehicle, did not hitch up the trailer, and went to loosen the activation caps. I found that on the left side, the trunnion (I think that is the correct name for the part that the spring bar goes into) would rotate through a wide range when loosening the activation cap. In the past the trunnion has only rotated 10 – 15 degrees while loosening or tightening the activation caps. The right side still acts that way. Is this normal behavior? If not, how do I correct it?
2. The instructions that I received with the hitch (purchased in 2018) say to tighten the activation caps to 100 ft-lb to engage the system. (The last page of this version of instructions is noted as 1007668R1.) I discovered that the instructions currently on the eaz-lift.com web site say to tighten the activation caps to 45 ft-lb. (The last page of this version is noted as 1007668R3.) Would tightening to the higher torque have damaged the hitch?
Thanks for any help.
Trailer is a 2012 Jayco Jayflight 26RLS
Tow vehicle is a 2013 Ford Expedition
  • Sorry for not replying sooner.
    At the same time as posting my original question, I had contacted the manufacturer's customer service / tech support. They said they were aware of the problem and eventually sent me a new hitch head. So I didn't actually try just tightening the Allen screws underneath.
  • There are adjusting screws on the bottom side. You can see them but stick the right size Allen wrench in it and snug them up.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
