JBarca
Oct 28, 2017Nomad II
flhtci2006 wrote:
So here's the deal: My trailer was loaded to 400 pounds below max weight. Tongue weight percentage was 12.3. I had just gotten the trailer back from a "repair" facility and was getting ready to head to the east coast.
I happened to notice they had installed the axles backwards, rt vs lt, not up vs down. I drove back to the shop to have them reverse the axles (130 miles). They reversed the axles and I headed home. The trailer had minor sway which I thought was canyon winds.
Also, the truck was working harder and gas mileage dropped from 8.9mpg to 5.8mpg. Also, two tires were running 45º hotter than the other two.
Slowed to 35mph in a construction area on a 7º down grade. Upon exiting the construction doing 35, I proceeded to speed up due to the grade.
The trailer then swayed dramatically and caused all 6 hanger brackets to bend, shifting the axles 2 inches to the left.
The road was straight with no bumps. They are saying it's my fault. There are a lot of mistakes they made prior to this (which is why they installed new axles...backwards) that really isn't pertinent.
Hi,
I may be able to add some to the discussion as I can see a several things going on and we do not know what happened exactly when.
First off, yes there is a front and back to the axle tubes. I am talking just about the axle tube at this point. You are correct, the wire hole is supposed to point to the rear of the trailer. The reason for this is, trailer axles have a toe setting built in from the factory. Depending on which axle manufacture makes them, they declare slightly different tolerances. You did not say if you had torsion axles or leaf springs as there are differences in them too. See here, scroll down a little and you can see the tolerancesTT axle alignment & install - Detailed (long lot's of pics)
Bottom line, the toe adjustment can be out of spec if you install the axle tube backwards. Wire hole to the front= backwards. If you manage to install it upside down, bottom on top and top on bottom, not likely but not impossible, the camber will be messed up.
The brakes have a left and right hand also. They do not work well when reversed.
When you took the trailer back, the shop could of goofed up a few things on the axle re-install to even more aggravate axle alignment to be worse. We need to be talking specifics here, the thrust angle on the front axle could be shifted out of spec if the play in the spring seat pin was excessive and fully skewed to the max play. This puts the front axle not square to the center of the trailer. Then the rear axle, assuming this is tandem, could be skewed the other way not making front and rear axle very aggravated in not being parallel. The axle alignment is now out, and if the hangers are welded on the trailer wrong from day 1, trust me it happens, then you can have a very out of aligned trailer grinding up rubber going down the road as the trailer is dog tracking the truck.
BUT... this mega out of aligned trailer will scrub tires badly but you may not get induced sway out of it that you feel "pending" other factors. You did not say what total weight the trailer was or what size truck you have. Do you have antisway control hitch? A heavy suspension truck can help hold this setup more stable then a soft sprung truck with soft tires on it.
Your hangers bent to the tune of the wheels being 2" shifted. This is another issue. We need more info on how your trailer is built. Especially if it is an I beam frame. Pics of the hangers and frame will help greatly. Trailers now a days have many axle hangers issues and are no where considered heavy duty. The side flex of the hanger into an unsupported I beam frame can and will crack the frame web over time. The lower flange of the I beam is so weak it flexes without much side thrust. The hangers if they are the long ones, 3 to 5" long, and have no extra support will bend in turns OR high up and overs on off road travel. The toy hauler guys who go off road often, sometimes reinforce their hangers before they start going in the outback.
Heat in your tires: Between possible axle alignment issues from the shop, bent hangers that then totally messed up the axle alignment, you can easily get heat from tire scrub against the road and it can affect your gas mileage if it is bad enough. You are dragging the trailer down the road rather then rolling it down the road.
Now to the brakes. I just helped my neighbor troubleshoot his brakes. He has a 28 foot, approx 6,500# trailer being towed with a 1 ton SRW Dodge Ram. Only 1 trailer wheel had any kind of braking. The front axle, both sides the wires were broke and on the rear axle, one wheel had a broken magnet coil inside the wheel. He only had 1 brake that had power to the magnet coil and it was very far out of adjustment. That 1 wheel was trying to stop the camper and not doing a very good job of it. There was no sway and the 1 ton truck was doing the braking.
On my camper, 32 foot, just under 10,000# loaded. I installed self adjusting brakes. One brake drum had 0.020" out of round runout to it and that allowed the self adjusting brake to adjust into that out of round and ended up over adjusting it. We are towing to camp and I am in town. I start out from the red light and the truck is up shifting very different. After a short distance of this I pull over and one wheel is smoking hot on the brake. Oh boy.. Let it cool, crawl under and un-adjust it. Here I have been towing out on the highway with a partially locked on brake. And before I could get home, I had to stop a second time and unadjust the brake for the same thing. Point is, I had one wheel almost totally locked on and I'm towing at speed with it. With the mass of the trailer and the size of the 1 ton truck, there was no sway.
To your situation, your rig started swaying on the way back from the shop. First tell us the weight of the camper and the size of the truck. Do you have and anti-sway WD hitch? Think back in your mind, when did the sway start to happen during your trip? Immediately when you left the shop and made it over 45mph or less? Was it after 30 miles of towing above 45mph? or less. There are a lot of factors in what went wrong. This one is not going to be simple to pin point. Once your hangers bent, that is a totally different scenario. The trailer is then severely out of wheel alignment. When was the sway in relation to when the hangers being bent? When did you realize the hangers bent?
Your going to need to find a better shop to do the repair, verify the axle alignment and correct as needed and if your hangers bent, odds are high your frame and hangers are going to need to be addressed so it does not happen again.
Really curious on how this will all play out. We too learn from you on these kinds of situations.
Hope this helps.
John
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 19, 2026
