philnoah's avatar
philnoah
Electric heaters for travel trailers
Can someone provide some information on they type of electric supplemental heat
you use in your RV. This is in lieu of using propane over extended stays.
  • I believe you will find that it is illegal to sell any small electric heater that DOESN'T have a safety shut off switch for tip-overs and the like, and has been so for enough years that you will be hard-pressed to find one, even in the junk stores.
    In any case, while there are different kinds (IR, oil-filled, ceramic, etc.) they are pretty much all 1500 watts and do the same job with pretty much equal efficiency.
    I have two such small 1500 watt heaters I bought a couple years ago for $15 for the pair at Wally's or Target or some such store. They work fine. One of them lives in the TT, one in my office in the sticks 'n' bricks.
  • Roy, thank you for the idea and explanation. You might have something there.
  • RoyB's avatar
    RoyB
    Explorer II
    This is just me but the most safest electric heater we have ever found for the RV trailers is the OIL FILLED ELECTRIC Heaters. These have no visible flame, no visible red hot cores, no heated dust smell, and no noise. Only goes click every now and then. If we need to move some air around abit will use the O2COOL 10-inch AC/DC/D-cell fans sitting behind it.
    Works great for us. We use two of the low profile oil filled electric heaters like these... We feel this is perfectly safe to use around small kids and animals and blowing curtains..
    Roy Ken
  • Thanks for info. Is the cube heater infra red and/or with thermo shut off?
  • We just use a cube heater. Set it up on the cabinet or where ever it's convenient, turn it off before we leave.
    Good luck, Carmen
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 03, 2025
