6_7_tow_rig's avatar
6_7_tow_rig
electric question
So over the years we have experienced weak 30 amp service at some parks across the country. Usually never a big deal unless its in the summer and we are running the A.C. Last year a park in Florida we stayed at could only manage about 105 volts and I was scared to death of frying the AC. Is there anything that can be done to "boost" voltage a few volts? I originally thought about using a cheater box that plugs into the 30 and 20 amp socket and using a dogbone 50 to 30 adapter to plug my cord into. I read where these can't be used when there's a GFI so that's out. Also what would you say is the rock bottom voltage before the AC is affected? I've read on here where somebody recommended rewiring the AC so it can be plugged into its own 20amp circuit at the box but that's beyond my electricity skill level.
  • We really like our Hughes Autoformer. We were baking in NY at a park with very low voltage several years ago. I overnighted the autoformer, and the high temps were in the low 70's for the remainder of our stay. Not the best shipping decision, but it has saved us several times since.
    I installed mine before the SurgeGuard, and plugged inline into the 30a RV power cord so I can leave the autoformer inside my rig (normally left unconnected).
  • fla-gypsy wrote:
    My understanding is sensitive appliances should not be operated at outside of +/- 10% of 120 volts. That would put the lower limit at 108 volts. When I have encountered this I switch everything else off or to LP and let the AC have all available power and monitor my voltage meter.
    Yes you can run the A/C at 105 volts. And yes when below about 110 volts, switching the refrigerator over to gas will increase the voltage so slightly, and also have 3 less amps being used by the RV. The compressor motor will draw much more amperage at 105 volts than the normal 120 volts. And in reality, the "Nominal" voltage is 115 volts, so +10% is 126.5 volts and - 10% is 103.5 volts. Anything between 103 and 130 volts it will work. But it will work much better over 108 volts with less amp draw, thus less heat in the compressor winding, and the compressor will be happier, it will turn faster and you will have more cooling capacity at 122 volts than at 108 volt.
    I built my own 120 to 132 volt transformer with a isolated 12 volt transformer rated at 40 amps (500 watts). Basically you wire the 120 volts to the transformer, then the 12 volt output to the black input wire and the 120 + 12 to the output black wire, carry the neutral through from input to output. With 120 volt input, you get 132 volt output. With 110 input, you get about 121 output. With 100 input, you get a acceptable 110 volt output.
    I was in the pits at Bowling Green Raceway, with my brother's 1967 Dragster! It was exciting, but the humidity was around 100% with a slight rain in the air, and 85F out during Father's day weekend. I was plugged into a 20 amp receptacle without any fuses (well I guess the 00 wire on the pole was fused someplace). Many other motorhomes where plugged into the same receptacles. I had to double up, and set my transformer to +24 volts, as the input at the end of 100' of extension cords was less than 100 volts, and I wanted at least 115 for the A/C.
    The Hughes Autoformer is the answer that you can use. It will boost the voltage by 3 volts all the time, and when it detects less than 112 volts it will automatically switch to the +13 volt coil, and boost the voltage to an acceptable level. Inside the RV you will enjoy the A/C and not know if it switched or not. The only problem is cost. $300 - $500 depending on the model. Normally because 50 amp parks do not suffer from low voltage, I would only buy a 30 amp model, as that is the likely time you will need it.
    I built mine for about $200, the transformers are not cheap. Mine is manually adjusted, not automatic like Hughes.
    Fred.
  • I have been using the 30 amp Hughes Autoformer for two years at varies parks and it does work. I found the red light coming on a lot during the summer but my mh appliances including AC worked like a champ. Once at a park, the electricity dropped and everyone was without appliances, except me. I went ahead and closed the circuit breakers as a precaution but my neighbors were confused how my RV was not affected.
  • Hi gbopp,
    Unfortunately I've not used an autoformer either. However they do work and there are at least 3 brands available.
    I'm unlikely to get an autoformer as I mostly boondock and urbandock.
  • 6.7 tow rig wrote:
    Thanks. Have you guys ever used one and if so did it work?
    I have never owned or used one, I just know they exist.
    Hopefully pianotuna will respond again.
  • My understanding is sensitive appliances should not be operated at +/- 10% of 120 volts. That would put the lower limit at 108 volts. When I have encountered this I switch everything else off or to LP and let the AC have all available power and monitor my voltage meter.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
