NekkidFish's avatar
NekkidFish
Electrical issue
On at least three occasions, after running something in the RV, we will go to plug something into an outlet, and it is not working. Once we do a reset on the GFI thing on the bathroom plug, the plugs then work.
I wish I could give a specific on what was plugged in when this happened, but I can't. It seems random.
Tonight we were trying to hook up the DTV ... so we had the TV on, and the reciever plugged into an outlet. When I tried plugging the Power Inserter into the same outlet, it had no power.
Once we reset the GFI, then their was power.
Can anyone shed any light into what might be causing this?
Thanks!
  • Had that happen once and it was a bad GFI.
    Happen when I used any outlet on that circuit.
  • If it is random and no particular appliance or plug seems to trigger the GFI fault, the problem is either the GFI plug or your RV wiring. Since the GFI plug is the cheapest and easiest to replace, I would start there. Does the problem occur when using two prong plug appliances?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 09, 2026
