CA_Traveler
Sep 02, 2017Explorer III
Sounds like a short. Disconnect the pump positive wire. Connect a 12V bulb across the fuse and it will light due to the short. Then start disconnecting down stream wiring points until you isolate the problem.
You could also use a ohm meter to locate the short.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
