firemedic08's avatar
firemedic08
Electrical Problem help
A friend of mine reached out asking for suggestions on what her electrical issue could be. I figured this would be a good place to come for thoughts and opinions.
She states they plugged their 2010 crossroads Zinger in to their house, and there was a pop and smoke. Now the lights are dim. I had her husband check the voltage of the lights and he says its at 7 volts. My thoughts are the inverter/charger has went bad. The Electrical outlets (110 volt) all seem ok. Only issue is with the lights. The Converter is a WF-8955PEC.
  • Is this a plug in that was used before, or is it a brand new plug in location? Usually what happens in a new location is someone does not understand RV plug in wiring, and puts 240 volts onto the receptacle. Then, she blows up and takes out lots of problems.
    Lights are dim because the batteries are fully drained. Get a battery charger onto the batteries ASAP.
    Have a competent electrician check out the receptacle wiring to ensure it is correct. Check operation of fridge, TV, and other appliances in the rig that can run of 120 volts.
  • You might have them check where the shore cable hooks to the 110v wiring in the under carriage of the trailer. Had my wiring blow apart when a wire nut vibrate apart.
Looking for advice before your next adventure? Look no further.25,173 PostsLatest Activity: Oct 26, 2025
