garmp's avatar
garmp
Explorer II
Jun 17, 2022
Electrical question
Been a camper for a while, but relatively new to the RV style. 26" Class C (actually a Class B+). Pulled into our reserved camp site & set up. Slides out, leveled, water hooked up, plugged into electric (with EMS) and ready to settle in. Hotter than blazes so the air was turned on. After a few minutes we lost power. As I frantically ran in circles and turned off the air & everything else I could find the power came back on. I thought that's great. Then I looked at the EMS and saw an E2 error code. Open ground. Being electrically stupid, I thought good it foud the problem. All was clear and up & running. Turned on the air again and within a few minutes it happened again. Not knowing what to do & ringing wet from the heat I removed the EMS and plugged directly in to the power poll. All worked fine.
Was I just dumb & lucky or what. It was far too hot to do without air as DW & I are asthmatics & have respritory issues. It was getting later in the day & campgroun was full so no place to go.
Was this a totally wrong move on my part or what should I have done?
thanks
  • IMHO, you made a mistake and should have insisted that you be moved to a power pole without an issue or they have a repairman fix the problem at the pole. You chose to ignore the insurance you paid good money for and the consequences of that decision can be devastating (or you get lucky and they are not).
    We pay for protection and sometimes that protection is inconvenient but you have to assume the worst and verify that the problem is your EMS (rarely) and not the campground power (often).
  • You were promised by the RV park that they supplied “good” electrical power. They broke their promise and, I’ll wager, offered no refund.
  • 2112's avatar
    2112
    Explorer II
    Where ignorance is bliss, Tis folly to be wise
  • I am sure that there are plenty of people in that campground without an EMS , you will not be the only one ! Not totally wrong if it worked , but then I do not believe in all those gadgets
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
